what about Jonsered
Old 07-22-2009 | 03:55 PM
Default what about Jonsered
so what about Jonsered saw engines for converting ??
I know a saw shop that has closed and I think the guy has a couple used Jonsered saws I could get cheap
Jim
Old 07-22-2009 | 04:33 PM
w8ye's Avatar
My Feedback: (16)
Default RE: what about Jonsered
The new Jonesreds look the same as Homelites
The Jonesred company is actually the daddy of the chainsaw as we know it. They had the first practical designs. They have remained in the forefront ever since.
Old 07-23-2009 | 03:55 PM
w8ye's Avatar
My Feedback: (16)
As Far as converting engines, you should study your candidate's layout
Carbs above the flywheel are hard to contend with
side crankcase reed valves are awkward
Roller main bearings don't seem to work out as easy as ball mains.
Magnesium crankcases are dangerous to be aggressively cutting on
Look for ease of conversion like can the crankcase be separated from the saw frame and how are you going to mount the crankcase to the plane
is the coil mounted on the engine
is the carb mounted on the engine or the saw frame
Where is the carb and exhaust going to be
What will the likely all up weight be
Do you have a plane for it
Old 07-26-2009 | 06:12 PM
thanks for the info
Jim
Old 08-17-2009 | 09:10 AM
I have only done one, a 40cc "Big Red" the engine is of the highest qualty. I would say if you get it cheap enough go for it. This one was a lttle heavy, but built like a tank.
ID:	1257830   Click image for larger version
Old 08-17-2009 | 10:03 PM
Iflyglow's Avatar
My Feedback: (79)
The Johnsered "Little John" model has a Quadra 35 CD engine in it.
Old 08-22-2009 | 07:47 PM
w8ye - could you elaborate on this?I'm just starting into a big Stihl chainsaw (thread here). What is it about roller bearings that's a problem?
Also, should I be worried about using a hacksaw and a milling machine on a magnesium case? I assume you're talking about fire hazard from sparks, grinding, etc.
KD
