RE: the hyper st PRO thread!
Well I just invested in Hobao's new Mini Hyper ST and wow what a little car. Firstly it really is mini but the performance is'nt. I have had alot of cars now and this technicly really is a masterpiece. The most impressive part is the front driveshafts constant velocity joints I think they are called more efficient than the large 1/8 scale car ones and they don't have that whip effect. also the suspension is fantastic handles well at speed off road does n't bounce off the ground alot absorbs all the bumps nice without bottoming out and stays quite flat like a buggy. I had a MT2 and a Firestorm HPI but this car will replace both of them. It is more stable very reliable so far and the engine is the easiest I have had to start. And is also very stable at around 225 and 235 degrees. Also does not lean out at half a tank and produces lots of power enough to spin the HPI wheels and tyres which are bigger on take off. It has 3 diffs front and back disc brakes which are awesome better than any other car I've driven or seen. Also alloy adjustable shocks anti roll bars 12mm hex hubs front and back chassis stiffners and a nice polished alloy tuned pipe. Also the .12 engine could be replaced with an .18. Hope Hobao are working on a new 1/8 scale truggy that will move things forward as far as they have moved the smaller cars as I realy like 1/10 scale truggys but this 1/12 is way superior than the fully upgraded hpi firestorm I have I will have to say the standard hyper mini is not as fast top speed wise but great everywhere else but an .18 OS TZ will fix that.
