RCU Forums - View Single Post - Kadet Senior - Taildragger Conversion -Mains
Old 07-24-2009 | 09:04 AM
rs670
Default RE: Kadet Senior - Taildragger Conversion -Mains
On the tank relocation...I did it with a dremel tool. Flex shaft would have made it easier but I didn't have one. It's a very worth while modification.
Engine mounts were relocated keeping the engine on exact same thrust line (precise calculations were necessary here)
I purchased the main gear from TNTLANDINGGEAR.COM
Just get on their website and tell them the plane you have. They will custom make the gear for you. I didn't even have to furnish dimensions.
The wheel pants are replacement pants for Sig's Rascal 40 ARF purchased from Sig. They're nice because they come painted in either red & white or blue & white
I bought smooth rubber wheels that fit the pants (maybe 1/8 or 1/4 inch bigger than original)
Tower Hobbies supplied the exhaust extension (part #LXCB00)
Tail wheel set up was Tower also (part #LXRWW7)
I used a Slimline fueler which works well (also from Tower)
Let me know if you need more info
