RE: Buggy track setup questions thread
You can also change the springs in your clutch to engage earler which will create less wheel spin. 1.1mm is the stiffest which gives it the pop of the line, so you may want to try some 1.0 or 0.9 springs to start with. Changing the CB will make a difference too.
