RCU Forums - View Single Post - progression from trainer to low wing
Old 07-28-2009 | 01:32 AM
combatpigg's Avatar
combatpigg
Default RE: progression from trainer to low wing
If you are totally proficient with a trainer, it wont matter to you whether the wing is mounted high or low. The progression has nothing to do with wing placement. It has everything to do with moving on to planes with higher wing loadings and less drag.
You might even find some planes out there considered aerobatic that are just as easy to fly as your typical trainer.
