It would work, but the inside corners would have the radius of the diameter of the milling bit, and not be square. You would have to know the size of the sheets to use the on the milling table bed.
Jim
ORIGINAL: Daniel_M
I still am seeking for a general tutorial on how to create laser cutting sheets, although thank you for your answer, I appreciate it!
My school has a CNC Miller, which does the same job as a laser cutter except with a drill bit- is that suitable for cutting out parts, precisely, so that one fits another without gaps?
Best of luck,
Daniel.
