RCU Forums - View Single Post - can I put monokote (via windex) on plastic
Old 07-28-2009 | 07:17 PM
CGRetired's Avatar
CGRetired
Default RE: can I put monokote (via windex) on plastic
Yeah, Irish. A three blade should work just fine with the sea-bird. A lot of folks use them for ground clearance issues. They are not that efficient (less than two blade.... and, if you believe this, one blade with counterweight..). Many Pattern folks use them BECAUSE of the tendency to "brake" as you decellerate, or throttle down. They will slow it down faster than a two blade prop.
Did Sushi for dinner tonite. Yum!!!
Hope your son-in-law is doing better. Fingers crossed and, of course, prayers are with him.
CGr.
