RCU Forums - View Single Post - can I put monokote (via windex) on plastic
Old 07-28-2009 | 08:12 PM
goirish's Avatar
goirish
Default RE: can I put monokote (via windex) on plastic
ORIGINAL: CGRetired
Yeah, Irish. A three blade should work just fine with the sea-bird. A lot of folks use them for ground clearance issues. They are not that efficient (less than two blade.... and, if you believe this, one blade with counterweight..). Many Pattern folks use them BECAUSE of the tendency to ''brake'' as you decellerate, or throttle down. They will slow it down faster than a two blade prop.
Did Sushi for dinner tonite. Yum!!!
Hope your son-in-law is doing better. Fingers crossed and, of course, prayers are with him.
CGr.
So far so good. If no infection sets in they may be able to save his arm Won't be able to use it much, but will still have it. RCKen said he was going to be in Toledo in Sept. and maybe we could get together and go flying. That would be nice. I think I will get a 3-blade and give it a try. A bit much for power but I didn't have a 80 4 stroke so the 90 gets the ride. Hot wings tonight at buffalo wild wings. Just like Emmeril, they kick it up a notch.
