RCU Forums - View Single Post - An MK 20 Size Conservation Project
Old 07-29-2009 | 01:24 AM
doxilia's Avatar
doxilia
Default RE: An MK 20 Size Conservation Project
Curare 20
Here are the inventory shots for the Curare. Fewer parts than for the Cosmos as expected as it is also a simpler model to build - standard fuse box construction with a sheeted turtledeck supported by a longeron above semicircular balsa formers. The nose/cowl area is also simpler with two blocks - one above and one below and two blocks on each side of the nose gear bay fairing into the wing LE airfoil. This model should go together fairly quickly.
[ul][*] Wing (first 4 shots)[*] Empennage (5th shot)[*] Fuse (remaining shots)
[/ul]
Fewer pieces in this kit that require 3D CAD rendition - essentially two nose blocks, and two fin blocks (LE and subfin).
The laborious task of tracing will commence after matching the parts listings (inventory) to wood thicknesses and dimensions.
David.
ID:	1245582   Click image for larger version
ID:	1245583   Click image for larger version
ID:	1245584   Click image for larger version
ID:	1245585   Click image for larger version
ID:	1245586   Click image for larger version
ID:	1245587   Click image for larger version
ID:	1245588   Click image for larger version
ID:	1245590   Click image for larger version
ID:	1245591   Click image for larger version
ID:	1245592   Click image for larger version
