Thanks for the comments guys.... I have taken the covering off the wing and discovered that the LE on each wing has about a three inch piece that has been dislodged. Something a bit beyond soft. I have bought materieal to make a splice. My intention is to cut the remaing leading edge at and angle on both sides and then make a patch of leading edge cut to the same angles.
Probably will apply some glue here too!
Some of the ribs are damaged and I will repair those also.
The inspection of the fuse reveals a cracked area that I believe I can force back into place using a 16# mall with care. Glue would probably work here too! A little weight and some time to cure and things should be good there. May apply a small sheeting patch over that area for a bit of insurance. All this to be done from the inside of the fuse.
Firewall and motor base destroyed. I have the materials to rebuild those too. Maybe a good place for some more glue. The nose landing gear is gone. Sooooo... I will either have to make a replacement or balance it real carefully on the mains...
.</p>
OK, make a replacement.</p>
Time constraints have just allowed me to assemble most of the needed parts. Rebuild to begin soon. I will be happy to keep you guys posted.</p>
If any of you want a hot tip, invest now in a glue company!</p>
</p>
Paul</p>
