[quote]ORIGINAL: soarrich
ORIGINAL: dirtybird
The cheapest solution is to just use more voltage on your existing starter. Going up to 15 v would probably solve your problem. At least I would try it. I use 24v on a starter rated for 12. I also have the miller attachment.
The cheap strip switch will weld itself together very quickly.
[/quote
I have been using mine since 2001 and it hasn't done so yet.
