RCU Forums - View Single Post - Problems on buddy box with 2.4
Old 08-01-2009 | 03:58 PM
goirish's Avatar
goirish
Default RE: Problems on buddy box with 2.4
ORIGINAL: flynnaire
You also need to check and see if the plane is using a servo reversing lead(electrical) for the aler. The Spektrum system 2.4 has a similar problem with that... Just a thought to add to the list.
Not sure I understand what you are saying. When the master tx is being used no problem. Only when it transfers to the slave does the problem present itself.
