ORIGINAL: flynnaire
ORIGINAL: goirish
ORIGINAL: flynnaire
You also need to check and see if the plane is using a servo reversing lead(electrical) for the aler. The Spektrum system 2.4 has a similar problem with that... Just a thought to add to the list.
Not sure I understand what you are saying. When the master tx is being used no problem. Only when it transfers to the slave does the problem present itself.
We have a GP Cherokee that exibited the same thing with with ail. only to find out that some 2.4 systems dont like electrical reversing extentions, being used on the Cherokee to pair 2 servo's. The spektrum system wanted two serperate leads
and as much as say so in the manual. The ail. would be erattic on one radio but not the other. So I soldered the wires manualy reversing them and problem solved. Thought maybe just maybe you may have run across the same thing here??
Shooting in the dark but????? it's cheap to cheak.
Inst: Futaba 8U super
Trainer DX7
not sure I understand, we are not using a servo reverseing extension. We may be using computer reverseing in the computer
