RE: ZDZ 50NG mounting pattern
Figured out the choke connection on Friday. Used one of those short brass servo "bushings", it was close enough to the ID of the choke arm. Picked up a 2-56/2-56 DuBro ball link, the 2-56 machine screw is a perfect fit in the bushing. A bit of locktite on the nut and cranked it down - not going anywhere. Did have to sand the ball link shorter to keep it from hitting the firewall. I'll run Goldenrod back to a 81MG (probably) to actuate the choke - still looking for a way to do that manually if possible - may try a bellcrank and turn it 90 degrees out.
