RCU Forums - View Single Post - Balsarite ?
Thread: Balsarite ?
Old 08-04-2009 | 05:54 AM
bps's Avatar
bps
Default RE: Balsarite ?
ORIGINAL: squeakalong
Stevenmax50: I'd be interested in how you used the Balsarite (fabric type?) with the Koverall. Did you use it to actually attach the Koverall to the model framework and iron the Koverall to it? Because of a real sensitivity to the use of aircraft type dope I'm seeking an alternative method of attaching the Koverall and then I can use the PolyC and water based paints.
Soft landings.
Joe
Joe, You can use the PolyC to attatch the Koverall to the framework just as you would use dope. I use a product called ModPodge available at craft stores such as Michael's. I use the same product thinned with water to finish the Koverall and prepair it for paint. ModPodge works well as a balsa sealer to, just have to be careful because it is a water based material and can warp thin structures.
