RCU Forums - View Single Post - binding trouble
Old 08-04-2009 | 08:50 PM
nobodytwo's Avatar
nobodytwo
Default RE: binding trouble
ORIGINAL: shleprock
I bought an ar6200 spectrum reciever to use until I have my ar7000 gets checked. I cannot seem to get it bound to my dx7 radio. I can rebind my ar7000 fine. When I bind the ar6200 the LED's go to solid when pressing the bind button. When I unplug the bind plug, the LED dims on the main reciever and goes out on the remote reciever. Any thoughts? BTW the ar7000 seems to work fine but I do not trust it after the crash.
Try this sequence if doesn't work time to call Horizon Service:
1) Charge your battery
2) Insert the bind plug in to the bind/bat channel (be sure the correct model is selected and the radio is OFF)
3) Insert the battery lead into ANY unused channel
4) Remove the bind plug after the led starts flashing
5) Depress the bind button and turn on your radio
6) Wait for the LED to stop flashing and go solid BEFORE releasing the bind plug on the back of the radio
The receiver should not be bound to your selected plane.
Happy Landings!
