 binding trouble >
binding trouble
binding trouble
Old 08-04-2009 | 06:24 PM
Default binding trouble
I bought an ar6200 spectrum reciever to use until I have my ar7000 gets checked. I cannot seem to get it bound to my dx7 radio. I can rebind my ar7000 fine. When I bind the ar6200 the LED's go to solid when pressing the bind button. When I unplug the bind plug, the LED dims on the main reciever and goes out on the remote reciever. Any thoughts? BTW the ar7000 seems to work fine but I do not trust it after the crash.
Old 08-04-2009 | 08:25 PM
The Ghost's Avatar
Default RE: binding trouble
Sounds like a voltage problem with your flight pack, I only use 5cell packs with my 2.4 JR stuff.
Cheers
Old 08-04-2009 | 08:29 PM
sportrider_fz6's Avatar
I had an issue like that with a 6200, it was a voltage problem. I had a low RX battery recharged and it was fine. (I'm using 4 cell 4.8 and haven't had a problem)
Old 08-04-2009 | 08:50 PM
nobodytwo's Avatar
ORIGINAL: shleprock
Try this sequence if doesn't work time to call Horizon Service:
1) Charge your battery
2) Insert the bind plug in to the bind/bat channel (be sure the correct model is selected and the radio is OFF)
3) Insert the battery lead into ANY unused channel
4) Remove the bind plug after the led starts flashing
5) Depress the bind button and turn on your radio
6) Wait for the LED to stop flashing and go solid BEFORE releasing the bind plug on the back of the radio
The receiver should not be bound to your selected plane.
Happy Landings!
Old 08-05-2009 | 08:26 AM
Thanks guys. I plugged the bind plug into the charge jack as per the DX7 manual. Of course that didn't work. I then plugged into the bind slot in the reciever and that did the trick. The manual led me astray.
Old 08-05-2009 | 04:55 PM
The Ghost's Avatar
I plugged the bind plug into the charge jack as per the DX7 manual. Of course that didn't work. The manual led me astray.
You have to have the correct switch harniss for that to work. The one with the 3 wires on the charge line, also used for the DSC(direct servo control) cord, was not a fault of the manual. On page 18 of the manual I looked at shows the binding plug pluged into the charge plug and it shows 3 wires.
Cheers
Old 08-05-2009 | 05:05 PM
I have a three wire switch from JR. I looked online and the manual for the ar6200 states that you put the plug into the bat/bind slot on the reciever. Like I stated, the ar7000 bound fine using the proceedure in the manual but the 6200 would not.
Old 08-05-2009 | 05:50 PM
The Ghost's Avatar
Sorry, I have seen people trying to do this with only the two wire switches. Do you rebind after the trim filght to reset the fail safe.
Cheers
Old 08-06-2009 | 07:55 AM
BarracudaHockey's Avatar
The three wire switch works on the 6200 as long as its plugged into the batt bind port.
There's nothing mysterious going on, the bind plug shorts signal and ground on the batt/bind port.
Old 08-08-2009 | 11:53 AM
nobodytwo's Avatar
ORIGINAL: The Ghost
Cheers
Yes and ensure that the throttle trim is all the way down.
Happy Landings!
Old 08-08-2009 | 01:16 PM
Thanks guys. Problem solved and I have rebound the reciever after getting it trimmed out.
