RCU Forums - View Single Post - YS 110 keeps going dead stick
Old 08-05-2009 | 10:56 AM
42etus's Avatar
42etus
Default RE: YS 110 keeps going dead stick
More info would be helpful, but if the fuel system is set up correctly, the most likely cause of deadsticks is that the engine is overheating. That can have a number of causes.
1. Not enough air flow around the engine
2. Engine is being run too lean
3. Engine is being over proped
Here's a couple more links on setting up and running YS engines.
http://www.probuild-uk.co.uk/factsheets/ys_engines.php
http://www.patternflyer.com/troy/?page_id=13
Hope that helps,
Paul
