RE: Stuck carb screws
Usually heat will free it up. first try your heat gun you use to shrink covering; heat it as hot as you can get it with the heat gun and usually it will free right up. If that doesn't work, put it in an oven and heat it a bit more using gloves to try to twist it free while it is hot.
