RE: RCLander products...
The SAPAC Modern Military Jet resembles the famous and very advanced Raptor Jet. The SAPAC Modern Military Jet exemplifies the same beautiful lines as the original fighter jet. The wing and body used in this Modern Military are specially designed to allow high G maneuvers, yet keep a very low wing load. The Modern Military Jet is a stable aircraft with excellent performance. Designed with twin ducted fans with brushless motors, the Modern Military Jet has great performance and power. You can fly any aerobatic trick desired and the power system designed for the Modern Military Jet provides the capability to fly it in more than low to moderate wind conditions. The Modern Military Jet is controlled with a 4-channel R/C system. On the ground you have control of the steerable nose gear, in the air you have speed, ailerons, elevator and no rudder. The large capacity and high rate LiPo battery provides exuberant energy and because it features a safeguard, it is impossible to discharge your battery excessively.
Specifications:
Fuselage Total Length : 44"
Wingspan : 31.6"
Main Wing Area : 3.982sq.ft
Wing Loading : 0.952oz/sq.ft
Flying Weight : 35.273oz
Power : EDF64X2
Thrust : 37.037oz
Color Box Dimension : 44.6" X 13" X 9"
Carton Dimension : 45" X 19" X 26" (4 color box per carton)
Transmitter : 4 channels
Receiver : Mini 6 channels
Servo : 8g servo
ESC : 25A
Motor : Outrunner 2830, KV3800
Battery : 3S 3000MAH 15C
Fan : Two, 6 paddle 64MM Electric Ducted Fans
What's in the box?
Aircraft: Pre-painted fuselage in USAF air superiority camouflage, wing and control surfaces; pre-attached decals, instructions, landing gear, styrofoam-safe adhesive, though we recommend using 12 minute epoxy instead. (Please see below.)
Mechanical/Electronics: Engines, fans and all electronics are pre-installed, lithium-polymer battery, four channel radio transmitter.
What's needed to complete?
The transmitter requires eight AA batteries. We recommend using alkaline batteries for better reliability.
Instead of using regular glue for construction, we recommend using 12 minute epoxy for maximum strength and durability in high-g maneuvers.
Aircraft requires minimal assembly: simply glue the wings and control surfaces on, mount the landing gear, install the batteries. Servos are pre-installed, simply plug in the connectors. The canopy fastens on to eight magnetic attachment points for easy access.
Additional Information:
$189.95
