RE: FUNJET
Hi CP,
I would like to go with your set up, could you tell me what motor i should ask Dan to ship me. could you give me a list of other items i need to order from Dan like motor mount,prop adaptor, prop nut ect, so i could order all in one shot.
I have a C.C. 45amp esc lying with me would that be enough or would be on the limit drawing 40amps at full thrust.(sorry new to electrics). I would also need a BEC for a 4s lipo if i use the C.C. which BEC should i order from Dan, or is it simpler to just get a new ESC if so which one for this setup.
I would be going with the stock fj, dont mind a few mph less but would the 1234 gone verticals like you mentioned earlier.
Would order the lipos you mentioned from H.C.
Thanks guys for all the help.
Chaitanya.
