RCU Forums - View Single Post - Pull-Pull screaming servo! Help!
Old 03-29-2002 | 06:11 PM
scoplin771
Default Bellcranks
I got mine from Don' Hobbies 800-972-6273 or you can order direct from Nelson hobbies, mine are Nelson Bellcranks. I have had good luck with the Du-Bro coated pull-pull cable and 4-40 threaded ends, crimped not soldered. If you call Dons you will find that he recommends coated Kevlar and doesn't use wire at all.
