Does the airsoft barrel allow more room for the IR emitter or is the standard WSN IR barrel sufficient.
The stock barrel flash that comes with it is weak. There is no way to remove it and the ir emitter from the barrel without destroying both. The Vstank Leo 2a6 airsoft barrel works nicely. Just cut it down to size, make a spacer to fit the recoil unit and glue it in place. It will take the HL Flash LED perfectly.
Anyone have the proper wiring ladder too do this. This tank needs recoil.
Use this diagram to hook up the recoil, connect the WSN Green wire to the HL yellow, and WSN red to HL Brown (see below). Then hook up the white and black switch wires on the recoil motor to pins J and K (see 1st post above).
Was this conversion done to a Torro IR T34 or the old discontinued WSN/Wasan T34?
Its a Torro IR T34. I wish the hatches would open. I did thread saw the rear hatch and install the switch inside it.
