RE: HELP first scatch build
Check your balance point, mount the engine neutral, this gives you a base to work from. Try these steps first. If no luck, lower the none prop side of the engine and record each adjustment as you go along. By lowering the non prop side, this will raise the bow up.
-Thanks
