RCU Forums - View Single Post - kv-1 work in progress
Old 08-11-2009 | 06:09 PM
daisycutter redux
Default RE: kv-1 work in progress
ok another update on my kv-1
filled in those holes behind the armour plates,with the armour plates cut to fit the holes
replaced all the nuts with styrene hex rod that got sanded off in the process
fixed the odd arrangement of the front fender supports
added more styrene nuts
finished off front plate minus working headlight im trying to get hold of and horn which will go on together as i want to see were all the wires go
widened engine decks
beefed up weld seams to look more like photos
not much more to do before i have to stop and wait for parts to become avalible i may add the "hump" to the rear rounded plate depending on which model i complete the tank as
ID:	1254540   Click image for larger version
ID:	1254541   Click image for larger version
ID:	1254542   Click image for larger version
ID:	1254543   Click image for larger version
