RCU Forums - View Single Post - Predator Rigger Progress
Old 08-11-2009 | 10:41 PM
BACKEMF's Avatar
BACKEMF
Default RE: Predator Rigger Progress
ORIGINAL: ghostofpf1
I thought the 540 10s had a kv of 3549 ?? On 3s that's only ~35000 rpm under load
Steve
Under load... yes... what exactly is your load? A fairly small boat. For the hull size the motor is pretty big. Give it a try but, a plastic prop at that rpm if it comes out of the water will shatter when it re-enters, most likely. Been there on less rpm with Graupner Carbon props...
