RCU Forums - View Single Post - polyurathane & polycrilic
Old 08-15-2009 | 01:44 PM
bigtim
My Feedback: (13)
Default RE: polyurathane & polycrilic
typical polyurathane is oil based, clean up with paint thinner, or mineral spirits,same stuff different name, it tends to build up faster, the coats are thicker and can add weight fast, the oil based material is fuel proof, when allowed to fully cure.
polycrylic, probably the most over used and inaccurate name for water based acrylic clear coat, I use Varathane Diamond finish for glassing, but any WB poly works well enough for the job.
of the water based material the Varathane is the most fuel resistant of the ones I have tried, its good for a couple of hours before it begins to soften up when fuel is on it after it has cued for a couple of weeks.
for painting over WB poly glass jobs I like using the www.warbirdcolors.com paints since there a simmilar product, there water based catalized urathanes, they use a cross linker to make the finish fuel proof to 15% nitro.
I have also considered using the clear for glassing, since it would make my finish coats entirely fuel proof, but the Varathane is cheaper and is easy to use so I have kept going with it, the material also can be recoated in a hour so the glassing goes rather quickly
