RCU Forums - View Single Post - Designing a new pattern model
Old 08-16-2009 | 07:16 AM
  #68
Alex Voicu
Default RE: Designing a new pattern model
Small update: added carbon fiber to the mounting plates for the motor, gear, rudder servo and tailwheel. The firewall is made of 4mm liteply and 200g glassfiber on both sides, but i'm thinking about replacing it with something stronger. I added 1.5 mm balsa sheets to the sides of the fuselage box and put it together to make sure all parts fit perfectly. So far so good.
ID:	1257051   Click image for larger version
ID:	1257052   Click image for larger version
ID:	1257053   Click image for larger version
ID:	1257054   Click image for larger version
ID:	1257055   Click image for larger version
