RCU Forums - View Single Post - EVSD-5U valve Install
Old 08-16-2009 | 01:00 PM
CraigG's Avatar
CraigG
My Feedback: (40)
Default RE: EVSD-5U valve Install
ORIGINAL: [email protected]
Looking for infomation??????
ANYONE, that has used this system and installed the Airline Restrictors is this to just slow the system down and dose it have much effett on the speed of the gear.
Pat Martin
Pat,
Most installations will require some restriction in the flow volume to keep the gear and/or doors from slamming up/down. This is unrelated to the delay you set between the gear and door sequencing.
For my particular installation (Skymaster ViperJet) I found that I needed more restriction to slow the gear down. I replaced one of the provided restrictors with a Robart, which has a smaller diameter. Note that a restrictor on either side (up or down) will affect the flow in both directions since the air is restricted both going into the cylinder and out. You usually have to experiment a little.
Craig
