RE: 2.4 Mounting question
I have been glueing about 1/4 in foom to the side walls toward the back of the plane one on each side. Then valcro to the foam and valcro to the rx unit. I do put the ant. in two directions , like the one on one side will be parrell to the ground and the other side pointing upward.
one of the reasond I put the two ant, (and the is if you have the twin ant) toward the back is that 2.4 has a real problem with line of sight. If anything is in the way of tx to rx unit it will hurt the signel, like engien , elect. equip.
change of mind, if your interested in this ask and I will take some pic's for you. I can't do it untill tomorrow anyway.
sticks
