RCU Forums - View Single Post - SIG: Hog Bipe vs. Smith Miniplane
Old 08-20-2009 | 03:48 PM
EF
Default RE: SIG: Hog Bipe vs. Smith Miniplane
I solved the Smith ground handling issues on takeoff very easily - by connecting a simple GWS rate gyro to the rudder channel.
It takes off with a long straight run as long as you like, like an arrow, very little input from the rudder required, and the gyro also guards against overcontrol.
Good for helis, so why not for use on fixed wing aircraft?
ID:	1259874   Click image for larger version
ID:	1259875   Click image for larger version
