RCU Forums - View Single Post - A Tip, And A Question...
Old 06-27-2003 | 03:15 PM
av8tor1977's Avatar
av8tor1977
Default A Tip, And A Question...
Hi,
When you take out the gasket under the cylinder to raise the compression, here is the stuff to use to seal it. It is called Yamahabond case sealer from Yamaha. A tube runs around $6.00. We use it on our engines in our ultralights as well and this stuff works great. I just used it on a Homey hop up I'm doing and as always, it sealed perfectly.
Now my question: On the carbs with a plunger bubble for priming, can you just run a "Y" fitting in your line from the gas tank, or do you need to run a separate line??
AV8TOR
