RCU Forums - View Single Post - A Tip, And A Question...
Old 07-10-2003 | 06:27 PM
mikenlapaz
Default A Tip, And A Question...
av8tor1977
It is called Yamahabond case sealer from Yamaha
Have you tried it on the muffler / head joint? Having a heck of a time keeping that sealed on Ryobi.
I chose to use the remote primer bulb (suction from engine ). Installed a small "T" from drip irrigation system into line going back to tank. The added line serves as a fill line for the tank. Plug when not in use and a filter in the tank.
Trying to get a Homelite weedie/blower to run. The attached bulb collapses once and stays depressed. Tried switching the line and no joy. Walbro carb diagram WT-318-1 shows bulb as either part of air purge or cover for fuel pump . The fuel line (inlet or outlet) is located on same side of carb as the fuel line entering the main body of the carb.
Any tips on how to printout a schematic large enough to read the numbers on the parts?
