RE: Help Nitromodels !
The default setup, is to use the two provided servos to control BOTH the elevator and ailerons.
In other words the right side servo is to move the right aileron and elevator AT THE SAME TIME, IN THE SAME DIRECTION.
Likewise with the left side servo.
You use the provided longer rods, that came with the quick release already affixed to join the ailerons surface to the elevator.
You then set your TX for ELEVON mixing.
It looks a little weird, but it flies fine this way.
The extra cord you see is a "Y" cable used to add two additional servos onto the tail to seperately control the elevators if you so desire.
However this requires a normal direction servo AND a reversed servo. In Micro servos these are difficult to find.
So you are best off using a set of Spektrum Digital Programmable Micro Servos ( 19.00 / ea ) and a Spektrum Digital Servo Programmer ( $24.00 ) to reverse the movement of one of the servers, to do this.
