RCU Forums - View Single Post - Elevator Servo in Exhaust Path
Old 08-21-2009 | 01:30 PM
crankpin
My Feedback: (15)
Default Elevator Servo in Exhaust Path
What are you guy's doing with the exhaust residue hitting your rear mounted servo's. I would think only one side is affected. I understand exhaust routed away from the fuse, etc., if this is done. Encase in miniature plastic baggie ? I had built a small half barrel type of piece to cover the front of the servo, epoxied to the fuse, but took it off, may screw things up back there with wind resistance? Any suggestion's appreciated.
Crank
ID:	1260315   Click image for larger version
