RCU Forums - View Single Post - GP Extra 300S 60 Build
Old 08-23-2009 | 05:48 AM
  #32
Andrewmc
Default RE: GP Extra 300S 60 Build
Got a problem with interpretation of the plans.
On the trailing edge of the wing frames it instructs to trim the sheeting so that it is 1/2" longer than the ribs, which I have done.
The instructions then show a diagram of how the TE should be sanded (photo 2)
But to sand it this way there is much less than 1/2" of sheeting. If I sand the sheeting back like this won't it affect how the plane fits in the wing saddle?
Also the wing TE ribs do not taper to a feather edge as indicated so this would require changing the shape of the ribs which would make it even shorter.
Don't quite know how to proceed. Any suggestions?
ID:	1261253   Click image for larger version
ID:	1261254   Click image for larger version
