RCU Forums - View Single Post - Pull start help
Old 08-24-2009 | 10:40 AM
davecooper
Default RE: Pull start help
Thanks, that would explain it. I felt sure that there must be a spring loaded component somewhere and it is obviously the pin in the conrod shaft. I take it that this runs on the plate once the engine is running. I will check to see if this is broken or seized, it does seem a bit short I must admit.
