RCU Forums - View Single Post - My first 2X2 pattern plane construction
Old 08-24-2009 | 11:58 AM
geoffroyBelgium
Default My first 2X2 pattern plane construction
I would like to tell you the story of the construction of my 2X2 pattern plane.
First, the construction of the wings
The rib are made of 6mm depron. I'm using a method derived from the laser method to cut the rib. A piece of depron are placed to form a comb. Afterward, the rib are cutted with a CNC hot wire. The rib situated at the extremities of the sheath are reenforced with 1.5mm plywood.
The rib are covered with 2mm balsa. The classical method.
If there is some reactions about the construction, I will post some pictures about the rest of the construction.
[link=http://www.lumay.be]my personal website[/link]
