RE: Pull start help
Hi
Have you got the pin out? if not the pin will push a small way inside the conrod bigend shaft before the spring full compresses. Shoot some oil down there and give the pin a light push in hopefully that will loosen it up.It only takes a few min to remove the crank shaft so it may pay to do that anyways.
Wozza
