RCU Forums - View Single Post - Engine Test Stand?
Old 08-26-2009 | 05:27 AM
CGRetired's Avatar
CGRetired
Default RE: Engine Test Stand?
I just use the aircraft that the engine is going to be used with. Most break-ins are ok after a couple of tanks of fuel, and that can easily be done at the field before you maiden the plane. It also shakes loose anything that is going to shake loose on that maiden, you can fix it before you fly.
CGr.
