ORIGINAL: Doug Cronkhite
I'm confused.. I thought the preliminaries carried over as a 'flight' and then was added to the semi-finals score. Was the semi-finals a completely new contest again?
The carry over points are in the column that say "Panel 1" and the "Panel 2" column are the normalized semis points. If you add Panel 1 + panel 2 you will get the semis overall points
http://www.fpam.pt/WCF3A09/Classific...semiFinals.php
