ORIGINAL: Ricardo M.
ORIGINAL: Doug Cronkhite
I'm confused.. I thought the preliminaries carried over as a 'flight' and then was added to the semi-finals score. Was the semi-finals a completely new contest again?
The carry over points are in the column that say ''Panel 1'' and the ''Panel 2'' column are the normalized semis points. If you add Panel 1 + panel 2 you will get the semis overall points
http://www.fpam.pt/WCF3A09/Classific...semiFinals.php
No, you don't based on what's on the website. Look at the previous post by Chad to see the proper scores. The scores on the website only show the prelim score and one of the panels from the Semis. For instance, try adding the two scores shown for Brett Wickizer and see if you come up with his total score... That dang website had me confused for a few minutes until I decided to check RCU...
