RCU Forums - View Single Post - Failed experiment - give me the YS
Old 06-28-2003 | 09:53 PM
PatternFlyer
My Feedback: (182)
Default Failed experiment - give me the YS
Steveg,
How high was your fuel tank?
Did you use By-pass setup with Perry Pump?
What size prop?
My 91SX-H will be mounted inverted with fuel tank on CG.
So far, it is still on a test stand upright turning APC 15x8 at 8400 rpm. rich-mid range.
I will have to adjust the pump today.
Maybe I have to test it inverted before going in to the airframe.
YS 110 will definitely howl your Swallow.
Another guy is using Tower 75 2-troke standard setup and fly AMA advanced. Not sure if the plane is EX version.
