RCU Forums - View Single Post - Tank position problem.
Old 08-30-2009 | 01:34 AM
  #31
Motorboy's Avatar
Motorboy
Default RE: Tank position problem.
ORIGINAL: DarZeelon
ORIGINAL: Motorboy
But most generally: Follow the building construction/plan of aircraft where the engine and tank will be placed in right place.
Some time the tank are in the kit of model airplane, and follow instruction where the tank are placed.
Jens,
This is the exact problem!
Most kits and nearly all ARFs, that have the engine mounted upright (or inverted), DO NOT place the fuel-tank at the proper level.
This is a fact.
If the engine is upright, the fuel-tank will most likely be lower than ideal!
If such a model is built according to plans, or in an ARF, according to the instructions; when the plane is flown inverted, the engine will be running significanly richer than it ran when the plane was right-side-up... This is because the instructions/plans tell the builder/assembler to mount the engine too high!
With the holes already drilled in the firewall, there is not much of a choice.
And as to the large hole in the firewall, for the fuel-tubing (in which most normal tanks' 'snout' fits); it is always located behind the crankshaft center-line; not behind the carburettor...
This means it is about 40 mm (1.5'' ) too low...
I do not had problems with the motor by tank positions recommended by instructions and plans.
Have not experienced the problem with the Kyosho modelairplane (Messerscmitt BF-190 and PT-17 biplane).
It's not every day we read about problems tank placement in the forum. How many have ARF model airplanes in total, and rare to complaint about the tank location. It depends on the tank and engine placement is critical to the flight characteristics and engine setting for some model airplane and engines who are sensitive by fuel mixture in relating to the tank location.
The second problem may come if a switch from 2 stroke engines to 4 stroke engine or vice versa and get problem without repositioning the tank to right height again because the height of carburetor is quite difference in the 2 - and 4 stroke engines.
The last problem are length between engine and tank who make more lean (climbing) or rich (sinking) fuelmix.
