RE: Kyosho Osmose 70, Sort of build thread (slow..)
Thinn , I also have just purchased an Osmose. I had always wanted one and finally took the plunge. After reading most of the threads, I was excited to get started, that is until I got to yours. Your thread stated that no matter where you located the "CG", the plane dives towards the ground while inverted. Are you still having this issue? And is anyone else familiar with this characteristic pertaining to the Osmose 70? If others are sharing this "diving" while inverted, I think I may not build the plane. I was hopeing for it to be fairly neutral in all axises. Is this wishful thinking.
