Ok I have this ESC
http://www.xaic.cn/english/zzcp/BrushlessESC.htm Its the BLE 18 if that helps at all
Here is a pic of what I have . RtR BtY and YtB That does not work Then I tryed all other combos and none work after i changed the initial set up it broke so i tried to go back the the initial set up and it no longer works
Also I have them lust wire to wire cause i was testing... That is not how i will leave them! Thanks Guys! Also If you want I ca make a audio file that has the exact BEEP that it does..
Here are the pics
And a link to the pic DIRECTLY
http://yfrog.com/5aphotodosj
