RCU Forums - View Single Post - Brushless Motor Upgrade Problems
Old 08-30-2009 | 04:12 PM
LSF2298
Default RE: Brushless Motor Upgrade Problems
Well, if you can get it working again, reversing the yellow and black wires would cause the motor to reverse. Be sure you are using the correct arming sequece when you turn the transmitter, then receiver on. ie.. you may need to advance the throttle control to full throttle and then back to minimum before the ESC is armed. You may also need to reverse the throttle servo control. also, the ESC my have failed Good luck.
