RCU Forums - View Single Post - Help with tornado BB
Old 08-30-2009 | 05:01 PM
UrcHobby's Avatar
UrcHobby
Default RE: Help with tornado BB
It can be a few things, make sure the throttle is closed when you are priming it, Or you might be priming it too much, when you prime the motor with your finger over the exhaust most times you can see the fuel coming through the fuel line. When it gets to the carb stop priming it. Other then that does the motor start? if so how does it run when started?
