Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Help with tornado BB
Old 08-30-2009 | 01:44 PM
Default Help with tornado BB
When I try to prime the engine by blocking the exhaust and pulling the pull start nitro shoots up from my carb. any ideas? also what are some good upgrades for this product
Old 08-30-2009 | 05:01 PM
UrcHobby's Avatar
Default RE: Help with tornado BB
It can be a few things, make sure the throttle is closed when you are priming it, Or you might be priming it too much, when you prime the motor with your finger over the exhaust most times you can see the fuel coming through the fuel line. When it gets to the carb stop priming it. Other then that does the motor start? if so how does it run when started?
Old 08-30-2009 | 05:37 PM
how would i fix the problem, should i take out the glow plug and turn it upside down or what?
Old 08-30-2009 | 06:46 PM
UrcHobby's Avatar
If it is flooded, remove the fuel from the fuel tank then remove the glow plug and then flip it over and pull the recoil a few times slowly and watch that fuel does not spray all over you. Once it is not loaded with fuel put the glow plug back in then fill back up the fuel tank and do NOT prime it just try to start it by putting the glow ignitor on and pulling it to see if it starts. If it does not want to start check your needles and set them back to factory and then retune.
Old 09-01-2009 | 09:51 AM
it finally worked, i drained everything out and adjusted all the needles, thank you!
Old 09-01-2009 | 03:43 PM
UrcHobby's Avatar
No problem, Now you can have some fun
