RCU Forums - View Single Post - Aileron Question
Old 08-31-2009 | 03:51 AM
speedair
Default RE: Aileron Question
a will cause the nose to pitch up. To set the ailorons properly you will need to centre the trims un screw the servo horn then have the two ends of the servo horns parallel to the wings then you adjust the length of the wires so you get both ailarons in the centre. Hope this helps
